Yale electric Fault code 25104
Code throws as soon as the machine turns on and stops anything from engaging. Comes back as sensor fault, replacing motor controller has made no difference and connection to the traction motor seems fine.
  • Posted 1 Jan 2025 00:20
  • By tpaps
  • joined 1 Jan'25 - 2 messages
  • New Jersey, United States
Replaced drive motor sensor hydraulic motor sensor installed rebuilt, hydraulic motor coupler and pump which were worn out hydraulic filter new VSM install installed with an updated CDF file after that now getting an 8976 code. It's actually worse than before. Still get the 25 104 code waiting to hear from Yale factory. guess it's the pump motor controller next good battery no shorts to frame originally before the VSM swap in new CDF file I was getting the 25104 more than anything and once it energized and stayed on it would run fine with no hiccups.
  • Posted 3 Oct 2025 07:00
  • By Pistolpeted
  • joined 15 Dec'18 - 34 messages
  • Connecticut, United States
Try speed sensor
  • Posted 31 Aug 2025 09:52
  • By tpaps
I have the same code 25104 I've changed the revolution sensor on the drive motor that did not work still the same thing. I'm in the process of getting a revolution sensor for the hydraulic motor. Will update you on this.
  • Posted 29 Aug 2025 21:59
  • By Pistolpeted
Anything figured out on this yet?
  • Posted 29 Aug 2025 05:04
  • By Stark23
  • joined 29 Aug'25 - 1 message
  • United States
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Mitsubishi FGE35AT
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
