Won't start re-post!
Hello again! I humbly ask for your assistance once again....I asked you guys earlier in help identifying my 1986 Forklift. We knew we had to replace the master brake cylinder and water pump. That has been completed. The forklift would start immediately, then die after about 10 seconds. It sounded great. It was determined that the lift was out of LP, so we went and had it filled. It now will not start. A real forklift mechanic came and checked all electronic parts, regulator, vacuum lines, dis. cap, wires, fuses, etc etc. We smell the LP, Still will not start. The Lift guy gave up. It wants to start, just doesn't....Clue, please????
hmmmm...I thought was model 42-EFGC15-13405... Is that wrong?
  • Posted 2 Jan 2012 01:12
  • Modified 2 Jan 2012 01:20 by poster
  • By michelle_a
  • joined 4 Dec'11 - 40 messages
you may have triggered the emergency cutoff in the lpg tank quick disconnect. shut off gas at the tank, and try to start the truck a few times, then SLOWLY turn on the gas again, feeling the hose to see if you feel flow in the hose at all.
  • Posted 3 Jan 2012 02:22
The motor ran great for about 10 seconds UNTIL we had the tank refilled. Now it will not start at all. It wants to, but does not.
  • Posted 3 Jan 2012 00:49
  • By michelle_a
42-fgc15 sounds like the model number, and 13405 like the serial number.
when this LPG fueled truck runs out of LPG, there is usually about at least 30 seconds where it will run fine at idle speed, but when you give it gas, it will choke and sputter (way too lean fuel mixture as it runs out of LPG).
Sometimes people assume that it ran out of gas when the gas was low as some other problem happened.
Since we are assuming that it is in relationship to changing the gas tank, I would have expected the "real forklift mechanic" to have checked, but you can recheck, to see if the rubber gaskets/o-ring that are supposed to stay in the tank half of the quick disconnect may have come loose and not in the truck half of the LPG quick disconnect valve. if there is any black rubber part in the half of the quick disconnect that connects the hose to the LPG tank, remove them and check for matching missing pieces on the tank 1/2.
ALSO
Since you recently had work done on the motor, and since some of these trucks had an optional low oil pressure shut off, I would be checking to see if this motor had oil and did not have a wire broken off near the side of the motor where the oil pressure sender is mounted, if this unit has a more than 1 wire oil pressure sensor/sender.
Are we clear that currently, this motor starts and runs for 10 (or so) seconds then shuts down? and then can restrat and run for another 10 seconds?
  • Posted 3 Jan 2012 00:33
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Aichi RX07B
Terberg YT220
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
