Toyota 7FGU32:
Won't run
Blinks a code 9 on the dash, any suggestions?
  • Posted 14 Jul 2011 04:53
  • Discussion started by cfsrepairs
I've gotten all codes cleared, but still will not run, not getting any fuel to carb.
  • Posted 23 Jul 2011 02:02
  • Reply by cfsrepairs
2 is an accelerator sensor problem. this problem can come up when you over rotate the pot by flooring the pedal with the floor plate removed but it can be an open wire. this can also come up when you have the pedal pot unplugged.
14 is idle potentiometer problem, can be over rotation. if you haven't done anything to cause these codes you may have controller issues. look at the controller last, they
r a r e l y e v e r fail. these codes will clear when the problems are cleared and the key is cycled
  • Posted 15 Jul 2011 11:27
  • Reply by toyzilla
easier to ask forgiveness than to ask permission.
now the lifts giving a 2 and 14 code, this a wiring harness problem?
  • Posted 15 Jul 2011 03:12
probably a broken wire at the distributor. the solid black wire is a tach reference and 9 means its missing. this can also be a problem with the grounds between the 3 and 4 cylinder on the head.
  • Posted 14 Jul 2011 09:57
  • Reply by toyzilla
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
