Won't power up
Turn key over and distribution board just gives a short beep every 2-3 seconds. Display does not come up. Checked key switch, access 1 connector, all fuses, distribution relay and not finding anything.
  • Posted 3 Feb 2021 04:31
  • By NickN
  • joined 3 Feb'21 - 1 message
Hey Nick, did you manage to find out what was causing the issue for your reach? I'm currently dealing with an RMD6000s that is doing the exact same thing. It'll beep every 2-3 seconds but I disconnected CA204 from the distribution panel and managed to get it to start up somewhat normally, just enough to get it pulled into the maintenance shop.
Battery voltage is reading 37.45 on the Fluke meter and all the fuses and relays check out. If you have any advice for this I would definitely appreciate the pointers.
  • Posted 18 Feb 2026 01:30
  • By Matthew_Bailey
  • joined 18 Feb'26 - 2 messages
Matt Bailey
What ended up being the issue? Currently having the same problem.
  • Posted 28 Oct 2024 22:56
  • By Mike_Duncan
  • joined 28 Oct'24 - 1 message
Check the emergency disconnect switch.
  • Posted 5 Feb 2021 05:38
  • By Arnie_Sandoval
  • joined 5 Feb'21 - 2 messages
Arnie
Make sure all access modules power connections are snug... had an identical issue on sp4000... turned out to be B- on access 5 loose connection.
  • Posted 4 Feb 2021 10:03
  • By cubapnea
  • joined 3 Apr'13 - 24 messages
If it ain't broken...you know...
Assuming you've verified battery voltage is good, I would start checking CAN wiring
  • Posted 4 Feb 2021 04:46
  • By Triggs
Ryan Pyle Ryan Pyle
Chief of staff, Logistics UK
Regional sales manager, Eneroc USA
US material handling & intralogistics industry manager, Beckhoff Automation USA
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Bolzoni SpA (Group HQ)
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Ryan Pyle Ryan Pyle
