Won't go in reverse
Hi, looking for some troubleshooting tips. Unit will only drive forward but not in reverse. Is there a wiring harness that runs down the handle? Was told that it started working intermittently in reverse then stopped all together. Are there contactors that can be cleaned? The unit has a lot of debree inside. Thanks in advance!
  • Posted 18 Jan 2018 23:07
  • By Nitroracing6
  • joined 18 Jan'18 - 4 messages
  • New Hampshire, United States
Thanks guys, I'll check it out. If it was a brake adjustment, wouldn't it stop when going forward as well?
  • Posted 26 Jan 2018 00:13
  • By Nitroracing6
Rob Morris
*also check the brake switch on the other side of the drive unit, might need adjusted
  • Posted 25 Jan 2018 17:07
  • By Ifixit
check the wire hardness down near the drive wheel. they tend to drag on the floor and rub through. it runs down the handle, near the drive tire and into the contactor panel
  • Posted 25 Jan 2018 00:15
  • By wickedb6
  • joined 25 Jan'18 - 2 messages
Thanks again for the help. Cleaning the contactors did the trick! The unit still has an intermittent problem where reverse will drop out depending on the position of the handle so I think the control cabling is damaged. Wondering if anyone makes a replacement cable or would I have to repair the one in there?
  • Posted 25 Jan 2018 00:04
  • By Nitroracing6
Rob Morris
Thanks for the help gentlemen, I will check it out. There was a lot of debris on the inside of the unit. Mostly soap shavings which could have dirtied up the contactors(s). I will clean them all. I do not hear a contactor pull in when switching to reverse. Plan on working on it tomorrow (Monday, 1/22) and will let you know my findings.
  • Posted 22 Jan 2018 01:11
  • By Nitroracing6
Rob Morris
Yes, start with the contractor. If you hear it click, but no travel, it's either the tips are burnes...or debris keeping it from fully closing. No click, check the switch.
  • Posted 20 Jan 2018 22:29
  • By Ifixit
OK, So when trying to operate the unit in reverse do you hear the reverse contactor pick up? I would start there. You have to establish if there is a problem in the control circuit or power circuit. If you have no contactor pick up, it could very well be your reverse switch in the control handle.
  • Posted 19 Jan 2018 05:01
  • By 1Crusader
  • joined 5 Oct'10 - 52 messages
I didn't do it, nobody saw me and You can't prove a thing...
Ncn 85TH
Ncn 85TH 2014
SMV (Konecranes) SL37-1200A
Ncn 85TH
Ncn 85TH 2014
