WIRING PRINT FOR MITSUBISHI FGC25K W/ ECU UNIT
WIRING PRINT HELP
  • Posted 14 Mar 2012 23:46
  • By ted_l
  • joined 14 Mar'12 - 9 messages
  • Illinois, United States
you most likely will have to have someone with the software and laptop out, and have the accel pedal relearned.
I should also mention that you should never test the red and white wires that go to the fcsv (vac valve mounted on top of the LPG regulator) and if you have, you may need a new ECU. it is a pulsed signal, but trying to check it with a light or other 'path to ground' can let the magic smoke out of the little black boxes inside the ECU.
  • Posted 23 Mar 2012 10:24
  • Modified 23 Mar 2012 20:19 by poster
Serie: AF82D0265 model FCG20K
  • Posted 22 Mar 2012 16:00
  • By alonso_reyes
  • joined 5 Jul'11 - 48 messages
  • kyku, France
montacargasmsi@gmail.com
the forklift will not start and when you start having very low engine rpm and off, LPG ​​gas does not reach the carburetor, I need to know how to work the FCSV. the fuel lock off voltage is lost after starting.
  • Posted 22 Mar 2012 15:55
  • By alonso_reyes
  • kyku, France
the actual serial number will be needed to be sure you get correct information, different ecus were used in different years and some customers got trucks with ECU or ECM before 2003 for optional speed control. All of which are different schematics.
What is the problem you are trying to fix? What is/are the symptoms?
  • Posted 21 Mar 2012 20:19
I am looking for the schematics for a mitsubishi model FCG20K. Any assistance would be greatly appreciated.
  • Posted 21 Mar 2012 15:53
  • By alonso_reyes
  • kyku, France
what kind of help do you need?
  • Posted 21 Mar 2012 05:02
  • By gshort
  • joined 29 Apr'09 - 10 messages
UN Forklift FD35T
Elwell-Parker ESI500-36
Lift Technologies Inc.
