Wiring diagram
I'm working on a toyota 7fgcu25 and don't have power to the solenoid that turns the LP on. Runs if I jump it to the battery. Need a wiring diagram
  • Posted 13 Sep 2024 10:19
  • By Tractorboy_13
  • joined 28 Nov'21 - 3 messages
Tractorboy
I had a similar issue not to long ago with the ground that powers the solenoid. I also put a ground from the battery to the solenoid harness and the forklift started. The problem was that the ground wire on the other side of the harness was broken. Follow the power wire through the harness and you may find a break through. Mine was by spark plugs 2&3. Good luck
  • Posted 18 Oct 2024 02:16
  • By Hemi
  • joined 9 Aug'22 - 13 messages
  • New Mexico, United States
Humberto Fernandez
Check fuel relay, dual fuel switch , fuel fuse. Fuses. All at or below fuse box. Solenoid activates from ignition circuit for distributor. If dual fuel, there's a switch by vaporizer. Make sure your 2 wires to distributor are good. Check grounds by 3 &4 cylinder on block.
  • Posted 18 Oct 2024 02:05
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
Nagano NUL120-6
UN Forklift FB20-35FZNLZD
Nagano NUL120-6
