Wire Harness on rebuilt Handel Don't match Jack wiring.
Been trying to get a clear wiring Diagram from Yale but they say unit is to old and they don't have a clear Diagram that is readable. The 9 pin wire control plug is the problem. If anyone can come up with a wiring Diagram, i would appreciate it.
  • Posted 26 Apr 2019 06:42
  • Modified 26 Apr 2019 06:48 by poster
  • By Prancer
  • joined 12 Oct'13 - 48 messages
Mr fixit, The wiring print you sent did the trick, the unit works good, only had to switch 2 wires, then unit worked good. Thank you very much.
  • Posted 30 Apr 2019 10:37
  • By Prancer
berwinten@msn.com
SERIAL NUMBER DOES HELP
  • Posted 29 Apr 2019 23:03
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
Thank you, it does have resistor control. I have managed to get it to travel in first and second speed , can't get to go in top speed.
Thank you for your assistance.
  • Posted 28 Apr 2019 22:34
  • Modified 28 Apr 2019 23:03 by poster
  • By Prancer
Does your machine have SCR or resistors for controlling the speed?
Edit: I think that should be a resistor truck and I found the Yale schematic and wiring diagram. List your e mail in your member info and I can send it to you.
  • Posted 26 Apr 2019 21:16
  • Modified 26 Apr 2019 22:16 by poster
Lift Tek Elecar
