Will not show full charge
Hello,
So we have charged this wave several times until it shows green. We even load tested the batteries and we know that the batteries are good, but the BPI still only shows the flashing battery light and the wave is behaving as if it's almost out of juice. Any advice on how to fix this?? Thanks
  • Posted 29 Dec 2016 09:27
  • By zach_m
  • joined 13 Oct'16 - 19 messages
  • Illinois, United States
Acts 2:37-39
Showing items 1 - 20 of 24 results.
Not sure if you still are on this forum, but trying to figure out what you mean by this statement. I want to reset my BDI.
" I connect it to two of the batteries on one side on the positive and negative posts that are NOT jumpered to each other.>
  • Posted 22 Feb 2023 09:44
  • By infinkc
  • joined 14 Sep'17 - 14 messages
The Crown WAVs are the best designed. I have this problem periodically and usually when the operators leave them charging overnight. I have a charger at home that works with AGM batteries as well. I just hook it up to two of the 6V batteries on one side and turn on the fast charge for about 30 secs, then turn on the key switch.
Yes, always use AGM batteries in WAVs, but Interstate has AGM batteries that will work with WAVs we always buy and over $400 less for a set over Crown's.
  • Posted 17 Dec 2021 03:32
  • By Tim_Batson
  • joined 17 Dec'21 - 4 messages
  • Iowa, United States
WAV50s have AGM batteries, which is why they are able to lay on their sides. I've found a trick to reset the BDI easily. Since the voltage passes through so many connections to get to the BDI it's a fairly common problem when batteries get older.
I have a car charger at home that I can set for AGM batteries. After I make sure the WAV's charger won't charge any more, I connect it to two of the batteries on one side on the positive and negative posts that are NOT jumpered to each other. Turn on the fast charge option and wait about 30 secs. With the charger still on, I turn on the key switch and the BDI is reset! The charger adds enough voltage to surpass the amount required for the BDI reset.
This trick was told to me by one of our Crown technicians and doesn't harm anything with the WAVs.
  • Posted 17 Dec 2021 02:52
  • By Tim_Batson
Replacing Keyswitch has worked for me at least a few times; easy to replace.
  • Posted 2 Jun 2021 23:19
  • Modified 2 Jun 2021 23:20 by poster
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Yes, the voltage starts at the controller then goes to the lower panel through the switches to tb 101-6 or 7 blue mast cable on right side to lower platform crosses to left goes up to key switch, other side of key switch splits to display panel and other wire goes back down to controller with white mast cable left side tb 102-2
So get same voltage before and after key switch but I will try the key switch today
  • Posted 2 Jun 2021 23:16
  • By Fixit
  • joined 27 May'21 - 8 messages
ChrisB
The voltage originates at the controller.
One of the Conductor Cables has at least 1 wire with high resistance.
Test voltage at the Keyswitch, when it is open and also when closed.
  • Posted 2 Jun 2021 21:59
  • By LaGrange
Well, the one I have right now, so the batteries after charged and rested all night are 25.9 volts with the machine on, but at the wire going to the key switch is 24.4 volts
Does any know if it's the bdi or the controller that changes the meter to full battery charge
  • Posted 2 Jun 2021 21:47
  • By Fixit
ChrisB
*Chris B, read this comment*
Replace the Keyswitch, before you do anything else.
WAV's use Maintenance Free batteries that stand on their side in the battery compartment, instead of sitting like a normal battery.
The probability exists that you need 4 new batteries for some of the WAV's that you look after.
  • Posted 2 Jun 2021 12:37
  • Modified 2 Jun 2021 12:39 by poster
  • By LaGrange
Anymore info on the Wave bid mod
I have a whole fleet to repair and come across the flashing battery often
  • Posted 27 May 2021 13:31
  • By Fixit
ChrisB
My crown wave is flashing two green LEDs on the left side with service wrench button. According to the service manual, this is service code #192. Explanation is very limited. Can anybody help?
  • Posted 23 Aug 2018 04:33
  • By fred_c
  • joined 23 Aug'18 - 1 message
34-35 volts? Your battery is dead or junk.
  • Posted 17 Mar 2018 07:00
  • By PESLLC
  • joined 10 Oct'13 - 35 messages
  • fl, -
DC
A RC3000 series with battery voltage under 36V static is clearly a battery issue, the battery needs to be extracted and tested, maybe low on water levels, may have a weak/ shorted cell(s), or sulfated, or if you can decode the serial number on the battery you can verify its age. Typically batteries are rated for 5 yrs of service with conventional charging habits :)
  • Posted 16 Mar 2018 14:32
  • By TheBatteryGuy
  • joined 16 Mar'18 - 1 message
No, the RC3xxx has a completely different BDI system with its own Curtis controller for the BDI gauge - a silver box with two rotating knobs/dials, normally next to the EV1/100 controller card. It is adjustable, via the knobs but I don't have any information on it.
  • Posted 2 Mar 2018 15:54
  • By techno_nz
  • Canterbury, New Zealand
Hello, I have a RC3020 It will not lift. It will do everything else. I have the Battery Red light on flashing. The battery reads 35volts when I check it. DO you have a wiring diagram or anything that can help me track this down. ANy help is very appreciated.
  • Posted 2 Mar 2018 07:16
  • By Vorz
  • joined 22 Feb'18 - 3 messages
  • Indiana, United States
Hello, will This work with a RC3020? Everything works except it will not go up or down. The battery voltage is reading 34 or 35.
Dash battery has one red bar and flashing. I'm pulling my hair out. Any help is appreciated.
  • Posted 27 Feb 2018 10:38
  • By Vorz
Dash battery has one red bar. I'm pulling my hair out. Any help is appreciated.
  • Posted 22 Feb 2018 13:52
  • By Vorz
Thank you!
  • Posted 10 Feb 2017 10:36
  • By ynot
  • joined 5 Feb'17 - 21 messages
You need a 24v relay, the coil fed from terminal board TB201-2 which had wire 2935 red/white wire they are numbered, and -Ve from lift pump terminal green wires attached, then the switched terminals +Ve from ED contractor which has red wires attatched, and other side the wire 2935, which goes to the bdi. So you are switching straight battery volts to bdi from ED contractor
  • Posted 10 Feb 2017 09:10
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
@southernviking, can you tell me what i need exactly to get it done. I have a wave lift that is having this issue. What relay terminal do i need? Where is the 2905 red/white wire , white wire located. -VE = meaning? i would like to bypass the wire to the bdi but not sure where to start. Thanks
  • Posted 7 Feb 2017 14:57
  • Modified 8 Feb 2017 13:47 by poster
  • By ynot
The problem is the batteries are a little old, and the voltage drop through all the switches etc before it gets to the Bdi, you can trick the bdi by charging momentarily so the charger pumps voltage in the batteries and raises the overall voltage but you disconnect before it's finished charging or drive it for 5 mins to lower voltage then charge it because it will say it's charged and stop charging, I am a crown tech, and we fit a relay at terminal board that bypasses batt voltage straight to bdi I think wire 2905 red white wire and a white wire on the board, -Ve on pump to coil, main relay voyage through relay to white wire on the board, this sends voltage straight to. Bdi
  • Posted 6 Jan 2017 08:34
  • By southernviking
Michel Denis Michel Denis
Maxlion MTF30-45-2WD
Terberg YT222
