Will not drive, code 265 Pot Hole not engaged
Hello , new to the page here, hope to get some help.
Have a JLG 2630ES that just decided to stop driving all of sudden, scanner shows code 256 DRIVE PREVENTED POT HOLE NOT ENGAGED one was a little sticky so did a hale Mary and replaced both switches with the new stile. no difference, scanner shows left switch operating opposite of the right, Switches are operating properly along with all linkages, have voltage threw the switches back to the lower controller ( switches are wired in series ) I did notice that if I disconnect the proximity switch the code goes away, and it will start to drive, but the left brake will lock after about 3 seconds
  • Posted 27 Apr 2025 09:38
  • By Richie66
  • joined 27 Apr'25 - 2 messages
  • Arkansas, United States
I, too, was fighting a JLG 2630S issue with the Pothole Switches. Thankfully I found this forum thread and saw the recommendation to enter the Machine Setup area (I needed to enter the Level 2 access code first to be able to make changes) and set the Proximity Switch from "0" to "1" and it completely fixed the issue. THANKS!
The 3121166 manual sure doesn't do a good job on this; the wiring diagram showed the switches in series, but the Section 6 Diagnostic Trouble Code chart for error 256 (page 6-9) clearly infers that is NOT the case, stating the Left switch connects to J1-9 and J1-10, with the right connecting to J1-17 and 18.
  • Posted 3 May 2025 00:08
  • By LorenS
  • joined 3 May'25 - 1 message
  • Missouri, United States
- Loren
Nice to hear...keep an eye on the battery trays, they are made of plastic and the corrosion and weight crack the upper sections a lot..I've dropped a few in my days..barely missing feet
  • Posted 1 May 2025 13:48
  • By Matthew_Reed
  • joined 12 Jun'23 - 113 messages
Thanks for the help, I went back threw the menu of the scanner, and noticed the proximity sensor was shown as not installed. Corrected the description and it worked, thanks
  • Posted 1 May 2025 06:43
  • By Richie66
These lifts pots can be a hassle...if you replaced them..make sure you changed wiring..they come set normally open I think and need to be normally closed...then verify only at around 6 feet both pothole legs come off both switches all the way..I've had a leg not opening all the way all the time..I ended up replacing both and readjusting both..then verify pox switch is working properly...use analyzer to change country and model..then power off..turn back off...reset to original
  • Posted 29 Apr 2025 12:44
  • By Matthew_Reed
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
Taylor T520M
UN Forklift FBT20NQZ1
