will not accelerate code 24
K21 engine will start and run but will not accelerate. Rpm will increase gradually when in neutral. Tried new accelerator pot no success. Grateful for any help.
  • Posted 5 May 2017 06:44
  • By fred_b
  • joined 25 Sep'15 - 18 messages
  • Connecticut, United States
F K Berger
Code E-24 is forAccelerator pedal position sensor signal circuit
-Accelerator pedal position sensor signal circuit is open or shorted
. *A malfunction occurs in relation between accelerator pedal sensors 1 and 2.
Did you clear codes after changing sensor....did you use OEM pedal sensor...? Was sensor installed correctly...the pedal sensor actually has two sensors internal to it...sensor A and Sensor B....if it was installed wrong then it will still not function normally...it has to show on sensor 1 a voltage of.6 Volts at rest with key on and sweep to a voltage of 4.6 volts at wide open...sensor 2 should sweep from.3 volts to 2.0 volts
  • Posted 5 May 2017 19:41
  • By kevin_t
