Hyster S50XL:
Which engine do I have?
I have a Hyster S50XL, SN C187V10599R.
After doing some research, I believe that I have the GM 3 liter but want to make sure.
Thanks!
  • Posted 23 Aug 2016 04:20
  • Discussion started by Carapace
Thanks all! I did verify that I have the Mazda M4-121G engine yesterday. It took a lot of digging on line. I read a TON of stuff and finally ran across some similar posts and other technical specs that led me to that answer. Getting verification here was the icing on the cake. Thanks again.
It's still crazy to me how difficult it is to figure out basic details, even with serial numbers, etc. I guess it is more about protecting the service industry than transparency. Imagine that!
  • Posted 24 Aug 2016 21:34
  • Reply by Carapace
GM was commonly used in that year model truck but the mazda was also an option.
There were 3 GM engine models used: 4-153, 4-181 AND 3.0L engines and only 1 Mazda model engine M4-121G
one way to tell is to look at the valve cover
The GM valve cover is long straight and has filler cap near the rear of the cover and PCV valve at the other end of the cover.
The Mazda (M4-121G) engine is different in that it has a slant to the valve cover, a breather in the middle in the slanted part and the filler cap on the rear side of the valve cover.
Note: orientation may sound confusing but when i say "rear" of the engine it is the "actual" rear of the engine. It does sit in the truck backwards so keep this in mind.
  • Posted 24 Aug 2016 08:59
  • Reply by swoop223
I looked that model up on X Part and the motor options are GM 3.0, Isuzu diesel, or Mazda. The older model S50XL used a GM 2.5, but not the one you listed.
  • Posted 24 Aug 2016 02:49
  • Reply by mrfixit
Are you sure? Why do you say that?
I will clean the block, etc tomorrow, so I should be able to get some definitive answer, but just want to know if there is some easy way to know for sure.
  • Posted 23 Aug 2016 10:54
  • Reply by Carapace
That's sounds right.
  • Posted 23 Aug 2016 08:02
  • Reply by mrfixit
UN Forklift FD50T-NJB3
Ncn 110TH
Ncn 110TH 2023
Linda Häkkilä Linda Häkkilä
