which cable and software used in the controllers ZAPI and ac2?
to set parameters and make programming
  • Posted 29 Apr 2012 23:25
  • By hysterbrazil
  • joined 10 Oct'11 - 101 messages
  • rio de janeiro, Brazil
Hi,
Does anyone can share the parameters to be set up in a controller ac2?
Thanks,
Luis
  • Posted 24 May 2023 04:16
  • By luis_v
  • joined 25 Feb'07 - 127 messages
  • Mexico
lvelasco@insercomm.com
My experience has been that you will still need a few various adapter cables, and the zapi main cable , which costs the same (from zapi) as the handset that does not also require a laptop.
The only advantage to using the laptop is the ability to save more than 1 setup for cloning setups across truck fleets, where the handset saves only the last setup that was saved to the handset.
There are some NACCO products I am aware of (VNA) that use a zapi wire guidance system that can not use the software, and require the handset.
  • Posted 19 Oct 2013 23:16
Hello ,
Please help me if you have find , with some software for zapi controlers. i repair elevations platforms for construction haulotte compact 8, which are equipped with ZAPI.i want to conect my laptop and use instead the console.
Regards !
  • Posted 19 Oct 2013 15:49
  • By gabi_g
  • joined 1 May'13 - 90 messages
gabihdh at gmail dot com
most trucks need an adapter cable to work with the zapi handset or laptop and zapi cable.
  • Posted 30 Apr 2012 20:30
Hello friend!
I have this program ZAPI 1.6 pc console
he is still in a program that I have steds
which references the cable? it connects all controllers ZAPI?
I work with Hyster and Yale forklifts
All programs have Hyster and Yale
Please add me on skype:hyster.brasil
  • Posted 30 Apr 2012 10:24
  • By hysterbrazil
You can get the Zapi PC Console software or as they call it: Zapi WIN Console V-1.06 and WIN Flasher V-1.15
Yale and Hyster dealers do sell this OTC in the states. The only information I can give u is Yale part #524154242 for the Zapi PC cable kit & Yale part #524154481 is the handset kit. Hyster dealers can cross these numbers to their part numbers as well.
Good Luck!
  • Posted 30 Apr 2012 10:01
  • By Mr. Twister
  • joined 1 Apr'12 - 12 messages
  • New Jersey, United States
Hi Mate
I think you can get a software win zapi or something which can be used through a PC ive heard people use them in the past, but the handsets are the easy to use and less hassle i guess.
Thats what I use the various zapi handsets.
  • Posted 30 Apr 2012 07:27
  • By elektrodrive
enquiries@elektrodrive.co.uk
i dont think any is avaliable ive worked on hysters with zapi controllers for over 20 years and allways used the handset i know hyster software does not work most zapi controllers the only truck it does work with is the J1.80XMT range
  • Posted 30 Apr 2012 06:18
  • By lifter01
  • joined 4 Jul'09 - 463 messages
I have the programmer handset! but would like to work with computer softwer ZAPI
  • Posted 30 Apr 2012 06:00
  • By hysterbrazil
you need get a zapi handset to programme zapi ac2 controller easy to use and fairly cheap from zapi
  • Posted 30 Apr 2012 05:49
  • By lifter01
