What happen to Cat TC120D?
O.K this story might be long!! grab a beer and chips well here we go...My friend bought Cat TC120D at the auctions he said it was a great buy!?until it doesn't work.He called me to look at the unit maybe a big mistake for me.He show's me white thick goop from the trani stick. The oil stick is clean.He thinks it's the head?? Frost plug?? Rad?? Trani lines that run into the rad could of burst inside because he dosn't call me to do the maintenance. I figure there was more water in the rad and sat in the cold inside the building.Well the old Perkins is coming out?why i don't know?at this time my opion means $hit. Rad out- white goop-torque convert white goop-Engine block white goop.Any steps to bring back the old perkins to life!!!
  • Posted 16 Oct 2009 00:07
  • Discussion started by LOGIC
Well after scraching the head found that the trani line that runs into the rad had burst and know the clean up. O Bliss!!
  • Posted 20 Oct 2009 02:34
  • Reply by LOGIC
white goop could be a mix of trani and anti fluids?
  • Posted 16 Oct 2009 23:30
  • Reply by LOGIC
Yikes recycling plants.......harsh environment. Some of the Perkins had removable piston sleeves. They would have hair line cracks in them and cause condensation in crankcase. Same for a cracked head and/or head gasket - compression test will determine that. As for the rad and trans......looks like a leak in the trans cooling side of the rad. I would flush rad and pressure test. The engine would build up pressure in the cooling system causing the coolant to leak into the trans cooling lines. Is the White goop coolant or pure water.
  • Posted 16 Oct 2009 23:13
  • Reply by Prentice
Prentice as far as i know it came from a recycling plant and store indoors,but the $hit that 's coming out is so thick and to clean!any sugests?
  • Posted 16 Oct 2009 22:48
  • Reply by LOGIC
Looks like a fun one LOGIC, I had a customer with a big pneumatic Hyster ( Marina truck ) Driver swore they did not drive it in the lake. There was even water in the steer wheel hub caps. We flushed all systems with fresh fluids 2- 4 times. The unit still runs today.
Does your buddy know where the truck came from before the auction???. What type of environment does the unit work in now??? Wet, cold, extreme heat???
  • Posted 16 Oct 2009 22:41
  • Reply by Prentice
edition #1229 - 8 May 2025
ROYPOW
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
