Hyster S120FT:
Wet brakes
Have a hyster S120FT that the wet brakes have locked up. They can be released when you open up the bleeder on the brake chamber, but will lock up again after you start the lift.
  • Posted 17 Sep 2024 07:36
  • Discussion started by DanielJ
DanielJ
Daniel,
I need you to check a couple things. First, make sure the brake pedal has enough play that it is not pressuring the system. Second, check the park brake lever or levers at the drive axle and make sure they move when releasing the park brake. If they do not, the park brake is engaged when you are trying to move. To make sure this is the problem. Release the park brake and try to move the lever using a pry bar. If it moves lever was rusted in the applied position. Good Luck
  • Posted 17 Sep 2024 22:40
  • Reply by Fishmech
  • Virginia, United States
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
edition #1234 - 12 June 2025
