WET BRAKES
THE BRAKE SYSTEM FITTED ON THIS MACHINE IS THE WET DISC SYSTEM , THE BRAKES ARE EXTREMLY SHARP POSSIBLY DANGEROUS AT TIMES , HOW CAN THE SYSTEM BE ADJUSTED ,IF POSSIBLE? AND CAN ANYBODY EXPLAIN THE FAULT
REGARDS PETER
  • Posted 14 Jun 2016 21:07
  • By peterb
  • joined 23 Feb'16 - 125 messages
  • lancashire, United Kingdom
it is easy to buy a universal flow reducer and reduce the flow to the booster to the best setting you need. I drive without and it works many years nice
  • Posted 29 Jan 2021 06:57
  • By tr_doctor
  • joined 4 Dec'20 - 186 messages
  • Netherlands
Regards
REALLY...? do you have a part#?
thanks
  • Posted 29 Jan 2021 06:54
  • By LP35
  • joined 10 Aug'12 - 32 messages
  • Quebec, Canada
a new valve is supplied from hyster that reduces the pressure from transmission to the booster
  • Posted 29 Jan 2021 06:30
  • By AAPEE
  • joined 28 Aug'12 - 76 messages
  • Brussels, Belgium
Hello , you can take the booster out of truck , without the booster works oke and no a sharp brake now. Booster are not possible to set some pressure so only result without it...
  • Posted 28 Jan 2021 05:58
  • By tr_doctor
  • Netherlands
Regards
hi. having same issue with yale truck GDP090VX K813V03293R
lift has 1873 hours. It was on rental and customer complains about the brakes. As soon as you it the pedal, operator is flying into front windshield....any help on this issue please. we have replace the booster and master but still sharp brakes.
thanks for your help.
  • Posted 14 Jan 2021 06:50
  • By LP35
  • Quebec, Canada
Thanks for sharing
www.protectiveplastic.com
  • Posted 15 Jun 2016 19:49
  • By protective_p
  • joined 24 May'16 - 1 message
  • India
thanks for reply. i will check this out
  • Posted 15 Jun 2016 17:24
  • By peterb
There is no adjustment for these brakes. You can adjust the pedal linkage. What type of fluid is in the axle? It should be universal transaxle fluid. Normally a problem with the brake effect is caused by improper fluid.
  • Posted 15 Jun 2016 04:01
  • By BREWSKI
Hoist Liftruck F180-36BOX-CAR
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
USD1
