Weak Horn
I have two Komatsu's doing the same thing. The horn is weak during operation. Voltage is 52 and 1/4amps going to horn. Replaced horn twice and also used OEM horn. It happens while using horn switch or leaving parking brake off. The input from horn switch goes into the traction card, but the output to the horn comes out of the hydraulic card. Do I have a bad card?
  • Posted 23 Feb 2018 01:45
  • By CLT1999
  • joined 23 Feb'18 - 5 messages
  • Illinois, United States
There is a Field Campaign for the horn on this truck. The horn manufacturer made some changes to the horn which require a new horn and a short wire harness with a diode to redirect current. Check with your local Komatsu Dealer or send an email with the two serial numbers to [email address removed] and we will let you know for sure.
  • Posted 15 Mar 2018 23:10
  • By Jeff
  • joined 8 Feb'07 - 61 messages
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
Tusk 500PGH16
Ncn 110TH
Ncn 110TH 2015
