Water leak
Hello
I have a 1996 Hyster 2.0 and have a water leak coming out of a pipe (sealed at one end) under the exhaust manifold with a small feed pipe coming out of it and it looks like it's going towards the water pump (maybe it's part of the water pump but I'm not sure)??
A part recognition and a part number would be great
Tanks
Kevin
  • Posted 24 Dec 2021 04:29
  • By Foleyexh
  • joined 10 Dec'21 - 13 messages
  • United Kingdom
K Foley
no problem Foleyexh
well the parts book shows 2 tube assemblies, one goes across the front, sort of wraps around the front of the block? that's not the one you described but just for reference sake and might need it down the road the part number for that one is 2022302.
Now the one you described that goes under the exhaust manifold? It's a sort of straight pipe with a slight bend in it and has a smaller tap line about 1/2 way or there abouts? (that small tap line actually connects to the other pipe from the looks of the parts book layout). Anyhow the part number for that pipe is 2022305. The o-ring part number is 1361827.
These are hyster part numbers, if you might want aftermarket ones i cannot help you there sir ;o).
Anyways this ought to fix ya up!
Merry Christmas!
Happy Holidays
  • Posted 25 Dec 2021 07:33
  • Modified 25 Dec 2021 07:35 by poster
Apologies, Swoop
LPG
  • Posted 25 Dec 2021 04:17
  • By Foleyexh
  • United Kingdom
K Foley
just to clarify, is this a diesel? LPG?
  • Posted 25 Dec 2021 01:49
Swoop
I hope this helps and thanks for your contribution
Hyster 2.0Ltr
Serial no: D001B04452T
Year of manufacture: 1996
Foleyexh
  • Posted 25 Dec 2021 01:03
  • By Foleyexh
  • United Kingdom
K Foley
if you had a model/serial number or at least what engine it has in it i might can get you some numbers. But what was previously mentioned about the tube oring sounds feasable, i've seen these tubes rot out and in alot of cases the tube would have to be replaced.
  • Posted 25 Dec 2021 00:40
Scott
Your the man????
"Happy Christmas and A Blessed New Year.
Thanks
  • Posted 24 Dec 2021 05:45
  • By Foleyexh
  • United Kingdom
K Foley
As far as part number l am not sure you can call closes hyster dealer and give them model and serial number they should give you part number. as far as part of water pump it is not there issbolt on side of block if you remove then take smallbypass hose off pull pipe straight out of side of waterpump it will come off pump you will see o ring on end of pipe some times pipe becomes rotted and won't hold o ring hope this helps
  • Posted 24 Dec 2021 05:24
  • By Scott_
Scott
