Wandering forks. No access
Raymond 425-C40TT forks go/drift down by themselves? not all the time. Does not matter if under load or not. Lift gives no error codes.
Also, we just inherited these dock trucks from a sister plant that is shutting down and no one seems to know the access code. I tried default 2 and 1 does not work any ideas. The machine looks like it calls for an eight didget code.
  • Posted 5 Nov 2024 23:51
  • By Jon_Grigelevich
  • joined 5 Nov'24 - 2 messages
JMGrigelevich
Mine was the right side ram was bypassing at the bottom
I removed the ram and disassembled the cylinder and at the bottom of the rod there is 3 small orings, 2 were broken I replaced those and it's been good since then. I had 2 2007 4150 with the same problem
  • Posted 9 Nov 2024 00:07
  • By Fixit
  • joined 27 May'21 - 8 messages
ChrisB
