Violent retract
Good day,
I have a Crown RR5725-45 that operates normally for all functions, save for the retract which bottoms out against the mast very suddenly and violently.
Don't get me wrong, the retract controls can be "Feathered" to mitigate this, but operators rarely do this...
I have several other models of Crown forklifts here, both newer and older, and this is the only machine which has this issue.
Is there a solution that can be done through software, or am I looking at a hydraulic valve issue?
Thanks in advance!
  • Posted 17 Dec 2024 03:19
  • By Br455Brute
  • joined 30 Nov'24 - 9 messages
  • Alberta, Canada
Once more, you're the hero of the day, Thanks
  • Posted 17 Dec 2024 06:41
  • By Br455Brute
  • Alberta, Canada
On the RR5700's you can play around with P9, P10, P11, and P14. These all have to do with the speed on the accessory hydraulics. 1 being the slowest and 9 being the fastest. If you have any mono mast reach trucks (RMD6000 or RM6000) there are performance settings where you can set it to automatically cushion.
Otherwise I would check your poly stops. If they keep slamming the reach assembly back into the mast your poly stops may be worn out causing nothing to soften the blow. These are located on the carriage assembly on the bottom. They typically are white or yellow with a hole in the middle for the bolt.
Unfortunately the best option is operator training if neither of those options above work.
  • Posted 17 Dec 2024 05:54
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
SMV (Konecranes) 20-1200B
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
