Princeton PB65:
Velocity fuse
How do i know if this pb65 has a velocity fuse for the lift cylinders?
  • Posted 19 Oct 2024 03:43
  • Discussion started by mrbob
  • Hawaii, United States
mrbob,
not sure on this one , due to the type of lift system on this unit.
you might want to contact the princeton dealer in your area and see if they can tell you. On most normal forklift hydraulic systems the velocity fuse is located inside the rod at the base where the packing gland is.
Your unit has a positive displacement system that allows the lift cylinders to raise and lower under pressure allowing it to lift and lower the load under pressure. Works very similar to how the tilt circuit works. Unlike the usual forklift hydraulic systems that are gravity lower cylinders.
The only two places i've ever seen velocity fuses are either in the base of the cylinder rod itself or is inside the fitting adapter at the base of the cylinder where the hydraulic line connects.
PAPE HAWAIIAN LIFT TRUCK is a dealer in hawaii, maybe they can answer that question for you? if they are willing that is.
There could also be a solenoid 'holding valve' on this system inside the control valve or in a manifold block.
Like i said, you should contact your local dealer on this.
  • Posted 21 Oct 2024 00:29
  • Reply by swoop223
edition #1234 - 12 June 2025
Taylor T650L
Tusk 500PGH16
