Vaporizer/fuel issue
I've had this Mitsubishi for a little over a year and lately in the cold it hasn't wanted to start/run very well. I replaced the oil pressure sensor, plugs, and drained the vaporizer so far. If it starts up and I give it fuel in neutral it will idol all the way up, however, if its in forward of reverse it doesn't want to go over a 1 mph and it wont lift more than a couple hundred pounds without bogging down. the low propane light also stays on right after I replace the tank, so i don't know if its a fuel consumption issue or vaporizer or both.
  • Posted 14 Mar 2025 18:34
  • By zach_reiter
  • joined 14 Mar'25 - 3 messages
The low LP light no longer stays on. I changed vaporizer however it's still running rough. The throttle body sensor make a noise when you turn key half on or off like a humming. Starting to think it's either a map, boost sensor or the throttle body assembly
  • Posted 9 Apr 2025 14:16
  • By zach_reiter
May check lock off valve and filter sounds like low LP pressure into unit. The other thing is look in LP coupler make sure no seal in it sometimes the seal from the tank gets stuck in it and won't let plunger collapse fully and allow fuel to flow
  • Posted 28 Mar 2025 21:26
  • Modified 28 Mar 2025 21:27 by poster
  • By John_Bradley
  • joined 10 Aug'22 - 303 messages
Jb69
zach,
on your dash display is it showing any E fault codes?
and you mentioned the LP low fuel light not turning off after you change a tank?
is the pressure switch located in-line before the vaporizer or after?
and about the vaporizer, does it have the lockoff solenoid built in or is the lockoff separate?
  • Posted 25 Mar 2025 13:40
Serial number for the forklift is AF82F00018
  • Posted 25 Mar 2025 06:35
  • By zach_reiter
what serial number is this unit?
do you know the model of the mixer on it? it should be imprinted on the top of it's cover.
  • Posted 16 Mar 2025 15:36
edition #1291 - 23 July 2026
In the latest Forkliftaction News , it is a week of product launches and humanoids. Chinese equipment manufacturer Heli launches its new heavy-duty G3 Series 12T-18T capacity forklifts on to the global market while Clark launches two new lithium-ion powered forklifts to the North American market... Continue reading
Terberg RT403
Mitsubishi Logisnext FD25T5M
Zhejiang UN Forklift Co., Ltd
Africa is the only continent with land in all four hemispheres. The equator passes through seven African nations (the Democratic Republic of the Congo, Gabon, Kenya, Republic of Congo, São Tomé and Príncipe, Somalia, and Uganda), while the prime meridian crosses five (Algeria, Burkina Faso, Ghana, Mali, and Togo).
Terberg RT403
