VAGCOM compatible linde H18-20 350 model forklift?
Greetings all
Along with salute you
Mi brother had two forklifts, one Linde H20 and one H18 2002 and 1999 respectly gas prophane vw engine forklift model 350
They had some problems, specifically the forklift run for minutes then sudently stops.
Coincidently I had a vagcom program and cable USB for volkswagen run in VW cars like Jetta, Passat and Bora, OBD II compatible with 16 pins and optional 4 pins connectors
I can run the vagcom program in this forklifts? the interface for 4-pin is not the same, in linde forklift had a female conector with 4-pin with YE VT RD And GN cables, while the volkswagen usb cable plus the 16 pin conector and 4 pin converter in two pairs conectors; they had this order : White (L, K lines) and Black (positive, negative),
Sorry my bad english, i am native spanish spoken
Best regards to all
Cristian, from Chile, L.A.
  • Posted 14 May 2011 01:26
  • By cristian
  • joined 16 Apr'05 - 3 messages
  • Valparaíso, Chile
please e mail it will send you photographs plugin
krzysztof
  • Posted 14 May 2011 05:59
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
This is very interesting, how i can known the equivalency between the pines?
ny risk of incorrect bridging in order to damage the netbook or USB port?
Best regards,
Cristian
  • Posted 14 May 2011 05:41
  • By cristian
  • Valparaíso, Chile
I plug into the 7-pin interface linde
Only four pins are used
krzysztof
  • Posted 14 May 2011 03:33
  • By krzysztof_k
  • śląśk, Poland
Specifically how to conect the VW cable in to the Linde Forklift
  • Posted 14 May 2011 02:13
  • By cristian
  • Valparaíso, Chile
What do you need to know
  • Posted 14 May 2011 01:54
  • By jolo
  • joined 19 Aug'10 - 5 messages
  • South Yorkshire, United Kingdom
