Toyota 8FGU25:
Unit has no tilt back
Unit is a 8FGU25.
It has no tilt back. If you rev the motor and tap the tilt lever forward then pull it back, it'll tilt back but not all the way. You can keep doing that and eventually reach max back tilt. Forward tilt works completely fine.
I talked to my service manager and he said it's the buttons on the control valve for the tilt spool. I swapped those out (the red wire was damaged), put the control valve back in, and still no tilt back. Everything else works just fine.
Anyone have any ideas?
  • Posted 12 May 2018 10:26
  • Discussion started by bruce_m
I'm having the exact same issue
Have you found anything
Thanks
  • Posted 11 Feb 2020 01:21
  • Reply by 21stsh
  • Illinois, United States
Thanks
  • Posted 11 Feb 2020 01:19
  • Reply by 21stsh
Thanks, I will check it out..
  • Posted 20 Jun 2018 00:25
  • Reply by art_flo
check the auxillary relief pressure and check valve
should be located on the main control valve
if no issue found there then i'd look at checking for cylinder bypass, one cylinder could have bad packing
  • Posted 19 Jun 2018 23:32
  • Modified 19 Jun 2018 23:33 by poster
  • Reply by swoop223
Were you able to find a solution to this?. I have a lift (8FGCU30) with the same issue. Tilt back will work intermittently, forward is ok.
  • Posted 19 Jun 2018 10:14
  • Reply by art_flo
edition #1228 - 1 May 2025
Crown WP302020
Terberg YT182
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
