unable to adjust one valve
I have a Mazda fe2.0 engine which I bought recently and the head leaked I pulled the head and cleaned and cleaned valves and installed new guide seals I cleaned valves also I installed new head gskt and when I went to adjust valves I couldn't get enough clearance on one exhaust valve my manual shows clearance is.013 for all valves I didn't measure the valve length wondering if anyone has ever run into this problem I checked the rocker arm and it looks fine any input would be helpful
  • Posted 19 Jan 2019 13:06
  • By Pooh
  • joined 19 Jan'19 - 2 messages
  • North Dakota, United States
I greatly appreciate the info that's what it was
  • Posted 20 Jan 2019 06:26
  • By Pooh
Look closely at where there rocker arm touches the top of the valve. There is a little rotating ball in there with a flat spot on it. That ball has to be rotated just right so the flat spot is what is touching the valve. Once the ball is positioned right, clearance.
  • Posted 19 Jan 2019 22:04
