turns on and shuts off
turn the key on, fork lift engages for about 3 seconds then shuts off. traced wires for shorts, cant find anything yet. code 12816 and 12819 come up. model is ERC050VGN36TE083 serial is A968N04521J
  • Posted 28 Mar 2015 09:20
  • By Universal
  • joined 28 Mar'15 - 5 messages
  • Indiana, United States
These trucks do not have a frame ground. All negative runs through wiring to battery negative. You really need a digital volt ohm meter to test this truck. You should not have any reading from truck wiring to frame. Your codes are for a open or short in the seat sensor wiring. check all the seat sensor wires for short to frame and to each other.
  • Posted 8 Apr 2015 23:17
  • By BREWSKI
yes its an A/C system
  • Posted 30 Mar 2015 21:59
  • By Universal
this information is not of much value to me, as far as offering you troubleshooting help. can you confirm this truck is an A/C system? (3 power cables to the drive motor?)
  • Posted 29 Mar 2015 09:36
  • Modified 29 Mar 2015 09:36 by poster
with the test light connected on the working lift to power, it shows a complete circuit on any stud. the test light also had a digital screen telling me the voltage whether positive or ground side. and its a great connection. but on the non working lift the voltage is low but still strong enough to light up the two colored LEDs, and strong enough to switch. almost as if its searching for a frame ground
  • Posted 29 Mar 2015 05:11
  • By Universal
test light is not too good an idea,,, always use an ohm meter... you may be just seeing leakage from moisture on the top of the battery...
  • Posted 29 Mar 2015 04:32
We took a test light from the postive cable at the controller on the Working lift to any bolt on the lift and had ground. The non working lift when doing the same changes the test light from power to ground a few times before the lift turns off. We removed the power and ground cables checking for anything that had shorted to the frame and both wires are clean
  • Posted 29 Mar 2015 01:34
  • By Universal
you say the -working- lift has a "frame ground"? do you mean a return to battery negative (shorted) through the frame? and the non working truck is clean to the frame on all power cables??
  • Posted 29 Mar 2015 01:27
  • Modified 29 Mar 2015 01:29 by poster
We have several times. All the way back to the master controller doing resistance tests and can't find any broken wires. When we compared to another lift exactly like it the only difference we can find is the lift that isn't working doesn't have frame ground but the working lift does
  • Posted 29 Mar 2015 00:19
  • By Universal
Hi Universal, check the seat sensor and wiring those codes refer to the seat sensor.
Regards Nero
  • Posted 29 Mar 2015 00:14
  • By NER045
Unicarriers FD80-2
Terberg YT220
Combilift Ltd
Combilift Ltd
