turn off...
Unit has condition where as you must switch the key OFF in order to regain either F or R when changing direction. Seems to be thermal in nature and only takes5 min. or so to being, but has no effect on hyd. side.........anyone had this issue?
  • Posted 17 Nov 2006 07:31
  • By BluzGtr
  • joined 12 Jun'04 - 5 messages
Is the truck fixed yet? Have not checked the Forklift action for a while. Could be a forward or reverse switch hanging up. It it senses both closed at the same time, it will shut down.
Is this EV-1 or EV-100? What is the serial number of the truck?
  • Posted 20 Jan 2007 13:14
  • Modified 20 Jan 2007 13:24 by poster
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Unit does this under straight and turing conditions, makes no difference. No jerking at all. As soon as you release/back off F & R demand, your done............ You must turn key switch to the off position. May take a few seconds to 5 min. of turning key off to regain use.
Again, this problem goes away with unit on Jack (no weight)
No handset at this time.....(old school Tech in denile)
Thank you LD!
  • Posted 23 Dec 2006 01:32
  • By BluzGtr
. Give me some more details. Does it do this while going straight? Does it jerk before it quits traveling, or does it just coast?
You need a hand set to plug into the motor controller to troubleshoot this. it will give you a trouble code.
  • Posted 22 Dec 2006 12:28
  • Modified 22 Dec 2006 12:28 by poster
  • By Liftdoctor
Question
  • Posted 22 Dec 2006 12:25
  • Modified 22 Dec 2006 12:29 by poster
  • By Liftdoctor
Toyota 8FD45
Terberg YT223
Sue Tomic Sue Tomic
