TSP6000 raises when aux functions commanded
Got a turret that raises slowly when aux functions like rotate and traverse are requested. Replace PVMR, PVML, swapped all other valves. Do not believe it's an electrical issues since no voltage is detected at cool when aux functions are commanded. Anyone come across an issue like this?
  • Posted 11 Jun 2014 01:04
  • By Rgshock99
  • joined 11 Jun'14 - 8 messages
Rgshock99
Turn out clean out manifold and valves adjusted receive balve a d recalibrate sense and breakout settings thanks for the insight
  • Posted 11 Jun 2014 05:57
  • By Rgshock99
Rgshock99
I've had this issue a couple of times before on another make of forklift.
One was a broken return spring for the main lift valve inside the valve block.
Main lift valve was slow to shut, electrically the lift stopped as commanded but if AUX functions where used within a few seconds the forks would creep up at same time due to slightly open main lift valve.
The other was a sticky valve assembly that controlled hydraulic flow between main lift valve block & the turret valve block.
Again aux functions could cause forks to either raise & sometimes drop at random.
It does sound like you have a sticky or faulty valve somewhere in the hydraulic system, I've never worked on one of these so I've no idea where would be best to look.
  • Posted 11 Jun 2014 04:26
  • By Forkingabout
  • england, United Kingdom
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Sourdough bread contains Lactobacillus reuteri, a probiotic bacteria. During pregnancy and breastfeeding, these bacteria can travel from the mother's colon to her breast tissue and be passed to the infant through breast milk. It offers various health benefits, including potential protection against breast cancer.
Terberg RT223
UN Forklift FBR25NQC3
