Toyota 7FGU25:
Truck starts, then dies immediately
I start the truck and it dies as soon as I move the keyswitch back to run. If I keep the switch in start, it will run (and accelerate). It seems to be losing fuel when it's not in start. Where do I go from here? S/N is 80025 if that helps
  • Posted 19 Sep 2012 06:48
  • Discussion started by Semperfiguy98
Just an fyi that signal wire is shielded and if you crimp the shielding the struck will not start like before.
  • Posted 23 Sep 2012 04:52
  • Reply by rogeriwt
And just in case you ever need to replace the connector and wiring, a replacement pigtail kit can be obtained from Toyota under the part number below.
Pigtail kit for Distributor.....90957-U9011-71
  • Posted 22 Sep 2012 10:48
  • Reply by L1ftmech
  • Tennessee, United States
Ok. I went back today and guess what.. Broken wire at cylindrical plug adjacent to distributor. Crimped female spade terminals on wires and it works fine. Thank you all for your help.
  • Posted 22 Sep 2012 10:16
  • Reply by Semperfiguy98
That makes perfect sense. I will look into that. Does anyone else have any suggestions?
  • Posted 20 Sep 2012 06:11
  • Posted 20 Sep 2012 02:18
Check the wiring that leads to the distributor to see if it has a broken tachometer signal wire.
We had one of these same 7F models that did this and a broken tach signal wire about 12 inches back from the distributor was the problem.
Apparently the 7F models are wired to be able to run without a tach signal in the cranking mode only, but will die immediately when the key is returned to run mode and a tach signal is absent.
  • Posted 20 Sep 2012 00:50
  • Reply by L1ftmech
I was thinking that, too. But when the key is in run the dash lights illuminate. That leads me to believe the key switch is ok. Also, there is a solenoid on top of the regulator with a black wire and a black/blue wire. If I apply 12 volts to the black and blue wire, the truck will run.
  • Posted 20 Sep 2012 00:31
if it was me, I think I would start with a meter on the 'run' position of the key switch, and if it had battery voltage in the right spots, I would then use the meter on the LPG relay...
  • Posted 19 Sep 2012 20:15
  • Reply by edward_t
The LPG relay is behind the sheet metal behind the left step. Does this truck say ECS on the engine valve cover? If so- I would suspect the distributor needs replacing.
  • Posted 19 Sep 2012 09:43
  • Reply by bbforks
It is an lpg truck. Unfortunately, I'm not very familiar with Toyota lift trucks. Where is the lpg relay located? And is there anything else I should check?
  • Posted 19 Sep 2012 09:25
This a LPG truck? if so check your LPG relay
  • Posted 19 Sep 2012 08:56
  • Reply by kevin_t
Remembering Otmar Kaup Aschaffenburg, Germany
edition #1232 - 29 May 2025
In this week’s Forkliftaction News , we look at the life and legacy of Otmar Kaup, the founder of forklift attachment manufacturer Kaup, a true trailblazer in the materials handling sector... Continue reading
Johnston, IA, United States
Knoxville, United States
Flower Mound, United States
LeMars, IA, United States
Spotlight on lifting industry London, United Kingdom
MHEFI awards 71 scholarships Charlotte, NC, United States
