truck starts and dies
I've got a hyster with a spectrum vaporizor and when I start the truck it starts and immediately dies. Thought it was a gas problem cause it starts just won't run, tested vaporizor and it was blowing 10lbs(way to much) so replaced it and same problem persists, pulled the gas line to the carburator from the vaporizor and nothing! So went to the elec shut off and pulled it apart and hit the key and have gas there so know the gas is coming in and not out any ideas???
  • Posted 24 May 2012 22:36
  • By straightup
  • joined 24 May'12 - 2 messages
  • Michigan, United States
One way I have learned to test for gas problem or another problem, I get a small lpg torch and place the nozzle in the mouth of the carb. Turn on the valve and see if engine starts and runs. If you get no hint of starting, it's not gas related. If it starts, you aren't getting gas. There are several things on the spectrum system that can prevent the engine from running. What happened to it initially? Was it running and quit or failed to start after sitting? You won't see gas in the hose from the vaporizer to the carb because carb vacuum is what opens the vaporizer.
  • Posted 26 May 2012 13:46
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Toyota 02-8FD25
Crown CG33P5
Evansville, IN, United States
Daleville, IN, United States
St. Louis, MO, United States
Uxbridge, Canada
