truck stalls when steering locked or hydraulics dead headed
I have a Toyota that when the steering or hydraulics are dead headed the truck immediatly shuts of and dies, we have replaced the intake gasket the regulator tuned it up, checked for vacuum leaks we can not find why it is doing this, anyone have any ideas?
  • Posted 25 Jan 2012 03:00
  • By 67dave67
  • joined 4 Dec'08 - 38 messages
  • British Columbia, Canada
Ed is right, the releif valve for the steering is in the orbital valve, you have to drop it down to make any adjustments.
  • Posted 26 Jan 2012 16:48
  • Modified 26 Jan 2012 16:49 by poster
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
and if the "dash pot thingy mounted on the carb" adjustment does or does not fix it, then the next step is to -properly- adjust the hydraulic relief valve settings, and check engine compression and tune up too.
  • Posted 26 Jan 2012 05:54
Does this happen only while idling? If so, does that have an adjustable vacuum operated dash pot thingy mounted on the carb that pushes the throttle linkage arm open a bit when the motor is lugged down while idling?
  • Posted 25 Jan 2012 07:17
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
