truck keeps On after the key switch is turned off
Hi guys,
I don't know if this is a silly question but I just want to be sure. I have 2 trucks same customer, where some times, after the key switch is turned off, the truck keeps ON normally. I'd say is a bad key switch, but this is the first time I see this, and it's happening on 2 trucks at the same time.
Is this a common issue?
thank you
  • Posted 30 Sep 2016 08:58
  • By CarlosCol
  • joined 13 May'16 - 28 messages
  • Bogota, Colombia
If the keyswitch and wiring is ok check the relays on the fuse relay card, probaly have a tip welded shut.
  • Posted 30 Sep 2016 21:49
  • By stam
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
October 12-15, 2026 - Detroit, MI, United States
