Trouble with my transmission heeeeeeelp!
Hi guys. well I'm in a pickle, I'm working on a Hyster specsaver s25/S25A I put in a cluch, pressure plate and trow brg. Cluch was shot,now that it's done, I can get reverse to go but when I put it into drive it stalls out. Can any one tell me what I did wrong. What should I be looking for. What should I try. If it will help mabe I can record what it does on my phone. Please Help Guys!
  • Posted 29 Oct 2016 11:37
  • By Theonlyjuan
  • joined 29 Oct'16 - 7 messages
  • Wisconsin, United States
Like my friend Pete says shake a hand make a friend!
I know this forum is old but i was wondering what you guys found to be the issue, i just got a 69 s25a up and running and after going through the monotrol valve completely i only have reverse even if i reverse the lines on the bottom of the monotrol. any help would be appreciated
Phil
  • Posted 19 Apr 2017 23:12
  • By Phil234
  • joined 19 Apr'17 - 1 message
Yes. A video would be best
  • Posted 10 Nov 2016 23:45
  • By bbforks
Can i email you pictures or a video of what its doing bbforks?
  • Posted 10 Nov 2016 13:04
  • Modified 10 Nov 2016 13:06 by poster
  • By Theonlyjuan
Already tried that. I originally thought it was the brakes, because it would go in reverse but not forward. SO I pulled brakes apart. Axle shafts come out when disassembling. BUT no luck.
  • Posted 10 Nov 2016 12:43
  • By Theonlyjuan
Could also be the brakes. You could take one axle out & see if the symptoms change
  • Posted 10 Nov 2016 12:01
  • By bbforks
Off the top of your head, what should I be looking for. Other than what we just talked about.
  • Posted 10 Nov 2016 11:55
  • By Theonlyjuan
Yes. took a look, I can see the fork move back and forth. IT seems to be moving in to gear right. I can see the ware pattern on them,and from what I see. looks right. But I do agree with you. Seems to me like two gears binding.
  • Posted 10 Nov 2016 11:52
  • By Theonlyjuan
Did you remove the top cover of the trans?
  • Posted 10 Nov 2016 11:44
  • By bbforks
Sorry just got home from work. Tomorrow I'll snap a few pics or a short video,for you to see. IF you see anything please let me know. I'd really appreciate your help and support. Thank you.
  • Posted 10 Nov 2016 11:34
  • By Theonlyjuan
Where are the forks for gear selection in the trans- in the top cover? I'm thinking maybe the forks didn't get back in their proper position- sounds like 2 gears are engaged at once. It's been awhile since I put a clutch in one of these.
  • Posted 10 Nov 2016 02:34
  • By bbforks
Maxlion MTF25-60-2WD
Maxlion FB25LI
