trouble code -31
Hello. got a Clark TMX20 sit down 36 volt forklift.
Serial #TMX250-0195-9597KF
Cuts out drive and throws a code -31. Can anyone help or have a description of the code. Is it a voltage error?
I managed to clear battery corrosion built up between frame and battery case. It worked for about a day, Dont think that may have been the cause.
  • Posted 8 Aug 2014 02:55
  • Discussion started by alvino_r
Como está amigo el problema con este código es el drive controller está malo replasalo
  • Posted 18 Apr 2024 00:24
  • Reply by DBell
The problem with this is the controller
Is you check and the wire the goes from the motor to the controller is good and no blow fuse
Replace the controller.
  • Posted 18 Apr 2024 00:23
  • Reply by DBell
Bue. Dia
Este equipo es AC no tienen carbones los motores. Revice el módulo y el motor y aparentemente marcan bien. Algún aotra idea
Saludos
Littoral translation
Good Day
This equipment is AC motors do not have coals. Check the module and motor and apparently they dial fine. Any other idea
Greetings
  • Posted 2 Nov 2021 00:49
  • Modified 2 Nov 2021 13:06 by administrator
  • Reply by Carlos_Gomez
  • GUAYAS, Ecuador
Carlos Gomez
are the contacts clicking? These trucks are prone for drive motor brushes sticking and direction contacts wear and do not make good connection.
  • Posted 1 Nov 2021 05:42
  • Reply by andrew_k
  • England, United Kingdom
Que tal amigo
Al fin pudiste detectar cuál fue la causa del error - 31 en tu equipo??
Saludls
  • Posted 1 Nov 2021 04:38
  • GUAYAS, Ecuador
Carlos Gomez
- FAULT NAME: VMN HIGH
- FAULT DESCRIPTION: wrong voltage on power motor outputs, failure in the power section or in the mosfet driver circuit or in the motor.
- CONTROL: master
- TROUBLESHOOTING: this test is carried out during initial diagnosis and in stand by.
-POSSIBLES CAUSES: problem in the motor connections or in the power circuit; check if the three phases are correctly connected; check if there is chassis ground of the motor to the truck frame.
Unhook battery at controller and do a diode check between BATT - and BATT+ (should read 0,3-0,,5v)
Fault in controller power section
Possible bad battery, excesive voltage to case of battery
ACTION REQUIRED: replace controller.
Good luck
  • Posted 8 Aug 2014 04:47
  • Reply by nacsand_n
  • Madrid, Spain
Advance CS7000
Illinois, United States
USD8,000
UN Forklift FB25N1QZ1
Your Focus
edition #1234 - 12 June 2025
Manitou MH25-4
SMV (Konecranes) 32-1200C
Johnston, IA, United States
St. Louis, MO, United States
Jefferson, WI, United States
