TRIPS OFF ON FAULT CODE MOD 9/O And MOD 5/0
serial number B460t01746m is not moving, key switch on, trips on code after 5 secs.....pls any help
  • Posted 2 Mar 2018 00:22
  • By northstar
  • joined 16 Jun'17 - 92 messages
  • accra, Ghana
It sounds like a low battery issue. These type of codes occur when battery voltage drops below threshold while operating.
  • Posted 2 Mar 2018 09:27
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
thank you very much, i really appreciate your rapid response.....pls i have rectified the fault its working now..
  • Posted 2 Mar 2018 04:44
  • By northstar
  • accra, Ghana
exactly but no password for the siscos display....the fault codes are mod 5/0 and drilling thru the log it says VMN low and the mod 9/0 is DRIVER OPEN and mod 1/0 CHAINS
  • Posted 2 Mar 2018 01:25
  • By northstar
  • accra, Ghana
Module 9 is in reference to the MIRIO controllers. Module 5 is in reference to the hydraulic controllers. You need to drill down through the fault logs and see exactly what the errors are for those controllers. Do you have a password for the SICOS display?
  • Posted 2 Mar 2018 00:40
  • By BREWSKI
What code is it showing?
  • Posted 2 Mar 2018 00:35
  • By BREWSKI
Toyota 3FD100
Toyota 02-8FD25
Toyota 3FD100
Toyota 02-8FD25
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
