Travel position light
Something is causing the travel position light to flicker on and off rapidly when traveling. Operation is interrupted when it flicks on. I used the overide switch to rule out the hand position sensors but the light still flickers. So my next thought is foot switch but the the machine only cuts out when traveling it works properly when lifting.
  • Posted 10 Mar 2018 07:03
  • By Jumpinjoe
  • joined 24 Mar'16 - 6 messages
Try closing the gates to see if it happens then. It could be one of the height switches and it thinks you are above 20 inches with gates open.
  • Posted 11 Mar 2018 10:41
  • By popeye
Sue Tomic Sue Tomic
F. Uchiyama
F. Uchiyama
