TRAVEL AND LIFT CUT OUT...LIGHTS ON DASH
i'm having trouble with a CAT C6000 with K25 engine. operator reports forklift won't lift or lower when interlock symbol is flashing on screen. does it once in the morning and works most of the day. then may do it again later. checked seat switch but OK. operator now reported both lift and lower out..and no travel. dash shows interlock flashing and neutral sign flashing as well. can't seem to pinpoint this issue. could this be a problem with the ECM?
  • Posted 24 May 2013 08:21
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
hopefully you have this problem resolved by now?
but generally if the interlock and the neutral light flash both simultaneously?
All this is telling you is that both the lift and drive interlock is activated because the seat switch is not activated, all functions are disabled.
Don't just check the switch, you should check the wiring under the seat all the way to the connector on the right hand side under the hood. Look underneath the seat cushion and see the wires going to the switch, make sure they are plugged in and the harness is not chaffed in any way. There is an open circuit somewhere.
good luck
  • Posted 28 Jun 2013 10:34
Tusk 350CGH20
UN Forklift FBRP15NQZ2
Hawker Powersource, Inc.
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Tusk 350CGH20
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
