Transmission Problems
This is a older 80's yale forklift we were running the it with no problems parked it for the night and came in the next day and it wont move, not shifting into any gears my guys said the oil was low but would that take out all the gears at once. any help would be nice.
  • Posted 28 Dec 2024 01:53
  • By Raymond_Thiele
  • joined 15 Apr'24 - 5 messages
  • Maryland, United States
Is this the location for the inching value?
https://photos.google.com/photo/AF1QipPWUYlQ4izT6QcVehTfw5PvxBZ1WWviwOhPwNqY
https://photos.google.com/photo/AF1QipMJ_XkBFz48qyqahn2N3bDJVGhTQS4erQdXFJEN
  • Posted 1 Jan 2025 01:02
  • Modified 1 Jan 2025 01:04 by poster
  • By Raymond_Thiele
You might check the inching, valve if filling up with oil doesn't work.
It might be stuck or have a broken return spring.
  • Posted 30 Dec 2024 05:24
  • By KenDan452
  • joined 11 Mar'18 - 1 message
  • Kolding, Denmark
The book says dextron II
  • Posted 28 Dec 2024 09:33
  • Modified 28 Dec 2024 09:33 by poster
  • By David_Miller
  • joined 9 Feb'24 - 13 messages
  • Michigan, United States
Dave
No bubbles at the end of the dip stick. I'll check the screen to see what it looks like. Do you know what type of fluid this trans takes
  • Posted 28 Dec 2024 07:34
  • By Raymond_Thiele
From what I have collected the low oil would not allow enough pressure to close the clutch packs completely. Is there bubbles on the end of the dip stick? There is a plug with a screen that if clogged would cause the bypass valve to stay open and no movement. Worst case Ontario I would grab some of that Lucas tranny rebuild oil and see if that works
  • Posted 28 Dec 2024 05:20
  • By David_Miller
Dave
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
JCB 533-105
USD1
JCB 533-105
