transmission problem?
Looking for help on trans problem engine has to rev high to move need a manual or any helpful tips
  • Posted 23 Feb 2018 01:49
  • By buck5775
  • joined 23 Feb'18 - 1 message
  • Indiana, United States
Often high engine RPM and sluggish or no transmission function can indicate poor modulation valve operation. So, first thing to try is remove
modulation valve plug on transmission valve body. Extract valve spool and observe if the small plastic filter/orifice is loose. This orfice/ filter has an O ring attached, remove O ring and tighten the plastic orifice.
A very common problem with early Daewoos and Doosans and if caught early a transmission failure can be avoided.
  • Posted 23 Feb 2018 06:35
  • By tom_p
  • Alberta, Canada
Michel Denis Michel Denis
