TCM T9:
Transmission oil pushing out thru dipstick when reverse is engaged
What can cause oil to push out of the transmission?
Only in reverse. we have checked all the seals on the shaft and piston. Box was OK until we fitted new reverse clutch packs,
didn't touch the rest of the box, now it has this problem.
Any Ideas?
  • Posted 24 Oct 2008 21:51
  • Discussion started by wonderphil
  • Mpumalanga, South Africa
Thank god for forklifts.
we found the problem, technician changed transmission but took the control valve off the faulty unit and put it onto the exchange transmission, but he never told anyone.
the control valve had bits of rag in it!!
Moral of the story?
COMMUNICATE.
Thanks for any and all replies
  • Posted 31 Oct 2008 02:12
  • Reply by wonderphil
wonderphil
Have a Model and Serial of unit.
Regards,
Doc
  • Posted 31 Oct 2008 01:04
  • Reply by Drlifttruck
Lift Trucks all the same, just painted different colors.
Doc
Email: kulsh@forkliftservice.net
Oil level perfect. Doesn't happen until you select reverse.
  • Posted 25 Oct 2008 00:32
It sounds like the transmission is over filled. Drain fluid and Check proper oil level
  • Posted 24 Oct 2008 23:54
  • Reply by Prentice
Taylor TX175
New - Sale & Hire
Taylor TX330S
USD159,500
Mobicon 2T
Nichiyu FB28PN77B367RRC
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
