Transmission-No Forward But has Reverse
Hey all, I need some help please. I have a hyster H50XL. I just bought it second hand. It ran well with no problems. I replaced both front brakes, wheel cylanders and Master cylander. I had noticed that the tramission fluid needed to be replaced, So I did. In driving it and testing the brake issue(which works) I started losing power. I have lost complete forward. It does have excellent bite in reverse though. I talked to mechanics at United Forklift and they told me that the transmission needs replaced. Can anyone give me any insite please on this issue. Anything I might have missed or that could help. I am very frustrated with this. Thanks in advance.
Also, if anyone has the mechanical drawings to this truck please let me know. I will buy them. Thanks again.
Gregorash
  • Posted 29 Aug 2007 03:16
  • By Gregorash
  • joined 29 Aug'07 - 1 message
  • Indiana, United States
Hey Greetings, how are you, did you manage to repair the transmission, how did you manage to repair it, can you let me know?
  • Posted 11 Mar 2023 11:22
  • By Angel_Perez
  • joined 10 Jan'23 - 5 messages
Angel
Hello where did you buy the clutch for Hyster 50 lift truck sndparts number please
  • Posted 9 Apr 2022 06:39
  • By CLAUDE_LEVEILLE
  • joined 9 Apr'22 - 1 message
  • Quebec, Canada
Claude
I dont know how to contact the author but hello Ray from Trevor TKO Forklift Kamloops
  • Posted 30 Jan 2008 17:52
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
If you remove the large drain plug on the transmission (faces to the rear) Watch out for the spring (not too strong, but can catch you). If the clutch pack has failed, you should find metal shards, and dark chunks of clutch friction material in the suction screen(behind the spring). This type of failure can be very expensive !
Pushing with the inching pedal partially engaged, and/or the wrong oil can cause this failure (The oil spec is J20A or J20C)
If the clutch has failed, an exchange transmission is the best option...The shaft updates will add $$$$
  • Posted 23 Jan 2008 18:03
  • By Ray_R
  • joined 23 Jan'08 - 4 messages
Gregorash,
Did you find your problem?
I just bought an H60XL with the very same symptom. I have new clutches on order which should be here in the next day or two.
  • Posted 10 Dec 2007 12:10
  • Modified 10 Dec 2007 12:11 by poster
  • By hybidder
  • joined 10 Dec'07 - 4 messages
  • Arkansas, United States
check your transmission oil level with engine running. then check your linkage ,is the inching spool going all the way back in.?
  • Posted 30 Aug 2007 04:43
  • By kevin_k
Hoist Liftruck F180-36BOX-CAR
SMV (Konecranes) SL37-1200A
Linde Material Handling
