Transmission Fault
Hello, I have a problem with a slow moving truck in both directions. Fluid level ok, slow to pick up when setting off. If you leave it running it seems to set off quicker. Thanks
  • Posted 14 Aug 2018 23:03
  • By Hairaiser
  • joined 14 Aug'18 - 2 messages
  • United Kingdom
If you are sure the inching spool is retracting fully you may need to run a pressure test. It could be a sticky pressure regulator spool or a broken spring.
  • Posted 15 Aug 2018 06:43
  • By BREWSKI
Yes have checked that, thanks
  • Posted 15 Aug 2018 01:36
  • By Hairaiser
  • United Kingdom
Check the inching free travel.
  • Posted 15 Aug 2018 00:56
  • By BREWSKI
edition #1237 - 3 July 2025
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
East Syracuse, United States
Saratoga, United States
Columbia, SC, United States
