Hyster H2.00XMS:
TRANSMISSION ELECTRICAL FAULT
We recently had a Hyster H2.00XMS that had a loose wiring connection in the loom behind the hand brake assembly. We rectified this, but now have no power to the transmission and hence no forward or reverse drive.
Does anyone have any ideas???
Any help would be gratefully appreciated.
  • Posted 21 Aug 2006 18:11
  • Discussion started by saddler
  • Staffordshire, United Kingdom
Hi Mike, settings recorded....
Many thanks for your valued response....
  • Posted 24 Aug 2006 17:16
  • Reply by saddler
I show 71Nm for the 1.5G, 96-103Nm for the 2.0G and 206-225Nm for the 2.5D.
  • Posted 24 Aug 2006 13:29
  • Reply by mike_n
  • Alberta, Canada
Hi kevin....
firstly thank you very much for taking the time to respond to our fault....
It is a lever control and as mentioned the initial fault was - "when the handbrake is put on (when the truck is running) the starter motor trys to engage" This stopped when we moved / secured the loose connections, but then the drive was lost.
I have it stripped down now in the workshop to change the ring gear, so when it is back together later this week what would you suggest checking first. Incidentally without being to pushy, would you know the torque settings for the bolts that hold the fly wheel on.
Once again thank you very much for your valued help.
  • Posted 23 Aug 2006 03:39
  • Reply by saddler
hi guys
is this truck monotrol or lever control. you may have joined the wires for the handbrke switch together which would cut power to the drive
  • Posted 22 Aug 2006 03:40
  • Reply by kevin_k
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
Ncn 110TH
Ncn 110TH 2023
Taylor T520M
SMV (Konecranes) 33-1200C
UN Forklift FBRP15NQZ2
