Trans Problems?
Hi guys , I recently purchased a used 2000 Komatsu model # FG40ZT-7 8000lb lift from my company it currently has trans problems and I was wondering if you guys could tell me if its worth trying to fix it or should I sell it for junk/ part out?
First let me say the lift and engine works fine although it dose have a lot of hours on it but it was well serviced.
The problem with the trans is that it will not back up, it goes forward just fine but when you put it in either reverse or neutral it seams that it is stuck in both forward and reverse, with the accelerator fully pressed the engine will not reeve up and it tries to creep forward at a strain any suggestions? Thanks
  • Posted 16 Jun 2009 07:10
  • By Papaoneone
  • joined 16 Jun'09 - 1 message
I would start by checking the inching spool and if it is operating O.K. I would check the trans solenoid and the forward and reverse switch, If these are all O.K. check trnsmission oil pressures as it may be the piston on the clutch pack is stuck. Good Luck
  • Posted 29 Sep 2009 22:29
  • By catlover
  • joined 19 Apr'09 - 4 messages
  • Victoria, Australia
Terberg YT220
Mobicon 2T
Zhejiang UN Forklift Co., Ltd
