Trans lock out
The unit is actually a H25ct. The problem I am having is that when you get off the unit the engine won't thottle up and won't drive. The unit has the hydrostatic drive with a fwd and rev pedal. If the unit decides to throttle up it won't always kick into gear. It will drive sometimes and runs great until you get off unit or pull park brake. I know both brake switches are working and the seat switch is working. I have tried to play with relays but can't seem to find one that is for the trans. Has anyone ever had this problem or can someone help me locate a schmatic or book for this truck. Thank you
  • Posted 7 Jan 2009 04:28
  • By chuck_m
  • joined 13 Jul'08 - 9 messages
  • Illinois, United States
Why do you want the truck to drive and throttle up when your not on it?This is a safety
  • Posted 18 May 2015 06:00
  • By edward_m
  • joined 11 May'15 - 111 messages
Your correct duodeluxe the question does read like that,Chuck what is the serial number of the truck if it is a 39x truck then nothing will work unless your are sat on the truck(unit?),if the machine is a 351 then a set switch was not fitted as standard so a bit more info may be needed to help you,
cheers herald.
  • Posted 31 Jan 2009 09:09
  • By Herald
  • joined 3 Jan'07 - 128 messages
  • lancashire, United Kingdom
Chuck; If I'm understanding you correctly, that is the way the truck is supposed to function. Nothing on the truck will work, including lowering the forks, unless you are sitting on the seat. If it is a problem other than that please elaborate.
  • Posted 31 Jan 2009 07:38
  • By duodeluxe
  • United States
duodeluxe
Taylor T520S
Morooka MFD20
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
edition #1293 - 6 August 2026
In this week’s Forkliftaction News, we look at the mixed bag of financial results released in the last week. This includes Hyster-Yale which improved quarter-on-quarter, but dropped modestly y-o-y, leading it to forecast a moderate operating loss for 2026... Continue reading
