Trans Brake
I have a Yale and the transmission brake does not work intermittently and then you get a trans brake temp warning and it basically derates. I did not write down the codes and then they needed it back to unload a truck. Any thoughts?
model. GLP050VXEVSF086
SER# B87B07724D
  • Posted 14 Jun 2015 11:46
  • By chuck_c
  • joined 10 May'15 - 18 messages
  • British Columbia, Canada
I have this issue as well, plus the truck "bucks" under acceleration as if the engine is turning on and off.
  • Posted 6 Jun 2024 22:15
  • By Raymond_Morell
  • joined 17 May'22 - 3 messages
I had a simular issue and traced it to the toss sensor. Do you have the speed limiting program in your vsm. in my case it wouldnt let me limit my speed. My Toss sensor actually came apart.
  • Posted 2 Oct 2015 09:31
  • By adam_g
  • joined 8 Apr'15 - 13 messages
  • Washington, United States
Trans fluid is universal trans/hydraulic fluid JD Hygard. You have to have a service level password to get into the calibration screen. You will need to contact your local Yale dealer to get the password.
  • Posted 17 Jun 2015 05:55
  • By BREWSKI
I believe the output sensor is the issue as well. What is the correct fluid for this units tranny? Hydratrans? What viscosity?
  • Posted 16 Jun 2015 14:16
  • By chuck_c
Thanks guys. How do you calibrate that transmission. Through the dash? I am new to these transmissions. How do I enter the service part of the onboard???
  • Posted 16 Jun 2015 14:15
  • By chuck_c
toss sensor for sure. under the floor with 4 wires in the plug. sensor will be breaking up.
  • Posted 16 Jun 2015 03:27
  • By kevin_k
Low fluid level can cause this. You may need to run the trans calibration. Either the TISS or TOSS sensor could be defective.
  • Posted 16 Jun 2015 00:55
  • By BREWSKI
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Terberg TT223
SMV (Konecranes) 33-1200C
