Yale GLC050VXNVSE085:
Trans Brake Hot , Fricton reduced
Truck is flashing,
Trans brake Hot
Friction reduced
  • Posted 12 Jul 2014 01:26
  • Modified 12 Jul 2014 01:27 by poster
  • Discussion started by ufl1996
  • Tennessee, United States
First off there are two speed sensors one is the TISS the other is the TOSS. The TISS has 3 wires, the TOSS has 4. Either one can cause this problem. You need a service level password to get into the dash setup.
  • Posted 8 Jun 2017 07:13
  • Reply by BREWSKI
I have the same thing happen I checked wiering. All good got new sensor still doing the same thing. Barely moves and forwards. Moves in reverse but flashes on and off. How do you calibrate it.
  • Posted 8 Jun 2017 01:34
  • Modified 8 Jun 2017 02:02 by poster
  • Reply by jordan_b
there should be a fault code on the dash or will say trans braking, this is on the VX models only..
  • Posted 30 Dec 2014 15:56
  • Reply by YaleTechnician
Have a Yale glc050 that is doing same thing. Did TOSS sensor fix problem?
  • Posted 30 Dec 2014 04:36
  • Reply by Boeing
you have a bad TOSS sensor on transmission. It sits or right side of top of trans, Its a 4 wire connector. check for loose connection, if ok, replace Toss sensor. once you do that ,calibrate transmission and you should be ok.
  • Posted 1 Aug 2014 15:25
Do you have the optional Duramatch (the Hyster name) trans which automatically decelerates the lift when you take your foot off the gas?
  • Posted 12 Jul 2014 11:04
  • Reply by bbforks
edition #1229 - 8 May 2025
Unicarriers FHGE35T5S
Taylor TT300
USD98,500
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
KION reports dip in Q1 revenue Frankfurt am Main, Germany
