Tranny fluid leak
When lift is running, tranny fluid leaks from bell housing/TC area. Is it easier to remove the engine or the transmission to access the TC?
  • Posted 16 May 2022 14:31
  • By Art_Chadsey
  • joined 16 May'22 - 3 messages
  • Alberta, Canada
I always pull the engine. I bet it's the tc seal leaking. Those trans tc seals are famous for leaking. I have done hundreds of them
  • Posted 22 Jun 2023 13:19
  • By Persley
  • joined 24 Jun'19 - 7 messages
  • Arizona, United States
Perfect! I'm suspecting my issue lies in that bell housing area. Like you mentioned, seal or TC I'm focusing on ATM! ??
  • Posted 19 May 2022 04:50
  • By Art_Chadsey
  • Alberta, Canada
Know problem you can do torque converter and seal also front pump with engine out but if you need to do anything else the trans must be removed.
  • Posted 19 May 2022 04:22
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
Thanks Scott, I suspected that would be the easier of the two evils. Appreciate the reply,????!!
  • Posted 18 May 2022 11:04
  • By Art_Chadsey
  • Alberta, Canada
Remove engine a lot more work to take out trans
  • Posted 18 May 2022 05:12
  • By Scott_
Scott
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Chandler, United States
Philadephia, PA, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
