Training area outdoors
Hi all, new to this forum and really just wanted to get some suggestions from you lot out there who may be in the same situation as me.
I have taken over the training for FLT at the current site i am based at now and we are mainly dealing with either casks, IBC, pallets. The previous instructor had set up a course long ago but used casks to outline the training course... The area is a bit awkward due to the ground conditions becoming muddy in the rain and winter seasons.
So i have put my foot down and requested that we move the training and utilise the space of an old carpark that has the proper ground conditions since we dont have any indoor areas to setup in. I am desperate to move away for the cask course design as it just doesn't work. This is where i am really looking for others opinions advice on what you have used to setup course areas in the past in an outdoor location. The ground is concrete and mostly flat but the odd slight slope so the typical barriers i have been familiar with for indoor smooth flat floors may not cut it and weather conditions wont really suite.
Are the 2 metre barriers with short feet on the one side the answer or has someone got any better suggestions?
Would really appreciate any help.
  • Posted 1 Dec 2020 01:44
  • By shaun_mckechnie
  • joined 1 Dec'20 - 2 messages
  • Fife, United Kingdom
S.Mckechnie
Like you I am currently RTITB certified but joined iTRUK as well so I could train people to operate safely but to a work standard rather than "test standard".
You could consider using plastic pipe to create the barriers. Would need the fittings to hold them upright and then horizontal and could have it high enough so that it moves if touched by the truck. Means an initial outlay but its waterproof and easy to move.
Good luck with the training.
  • Posted 2 Dec 2020 00:35
  • By Tat2dPete
  • joined 29 Sep'20 - 41 messages
  • Strathclyde, United Kingdom
Pete
Aye the casks for us are just spaced out and I have put them a critical turning points to give them the feel that they need to be looking around at all turns but its not the same, it is pretty easy still to get through.
I am currently RTITB but can't see us ever moving.. but in my earlier years starting out i worked up north and there are that many sites to cover we would usually get away with using pallets if the site actually had any decent flat ground, but this was rare. So we just had to adapt as best as we could. Now though being based at 2 sites and bringing them to the one site for their novice I just feel we can do better.
There is only one place on site they use industrial racking and its for one small group on site, the majority will be moving a skip, pallets or IBC's outdoors.
I had considered using empty IBC's to create the barrier for the chicane but the fact they will be picking up IBC's during the training i just felt they would be swimming in a constant IBC's.
I train both, and quite regularly. Though with the refresher for the guys at the warehouse that just move casks I tend to keep them on site demonstrating their ability to safely handle casks in different scenarios as they are always working in outdoor open spaces, but now also including the driving in and out of warehouses with the new FLT's we got on site recently that are aimed just to minimise the manual handling aspect with the long warehouses (been there and don't miss it). Otherwise some refreshers i will just get along to the static training course and cover them there.
  • Posted 1 Dec 2020 20:34
S.Mckechnie
Hi Shaun
Think we must work in the same industry as my predecessor did a similar thing.
Like you I did not feel comfortable with using casks as they are pain to line up properly.
I have used the barriers you mention, they are okay as long as the wind isn't blowing a hoolie if you have the feet in line with the barrier.
I have managed to get round the issue of using the chicane by joining the new kids on the block (iTRUK) as they have effectively done away with the chicane and operating the truck to the test written in the 1960's.
Are you using Industrial Racking at any point in the training or is it purely outdoor training?
Do you have any empty IBC's or stillages you can use if you need to create a barrier?
Are you training novices or experienced operatives?
  • Posted 1 Dec 2020 19:54
  • Modified 1 Dec 2020 19:55 by poster
  • By Tat2dPete
Pete
Johan Leveque Johan Leveque
Vice-chair, ALICE - (Alliance for Logistics Innovation through Collaboration in Europe)
Co-CEO, LIS Logistische Informationssysteme (LIS)
Regional sales manager, Battery Builders
SVP business solutions for the Americas, Dematic
The term "Spring", referring to the season, originated in the 14th century as "Springing time", describing how plants "spring" or burst into life after winter. In the 16th century "Springing time" was shortened to just "spring" for the season of new growth.
