traction issues
Hi Guys,
can anyone help with a repair manual for this truck please, we have various problematic traction fault and in need of wiring diagrams please.
Thanks in advance
  • Posted 26 Mar 2015 05:25
  • By feebs
  • joined 17 Nov'14 - 50 messages
  • Yorkshire, United Kingdom
yeah i had to deal with a yale/schaeff truck that had dual curtis motor controllers in it one time. Went through the same thing when i had to replace one.
the master is setup as '0' and the slave is set as '1' i believe.
just hook up the handset and verify what the settings are at
then make changes if they are not correct.
  • Posted 28 Mar 2015 23:31
Hi Swoop, this is one thing we was unsure about and are going to look at this on Monday when we get back to the truck.
  • Posted 28 Mar 2015 05:15
  • By feebs
When you replace a dual controller system controller usually they make the right controller the master and the left the slave.
Did you copy the settings from the left controller and then write them to the new one using the handset?
You would still have to go in and set that one to a slave i'm pretty sure.
  • Posted 28 Mar 2015 04:26
Hi Guys, sorry, have more info, Translift Bendi, yom 2008, model BE4208 2ss, Serial number TL7658. It has rear drive motors located under a side removal type battery, the truck has 2 Curtis controllers (type 1244) located to the right side front of the driver compartment and 1 main Curtis unit controlling steering etc, theres is 1 main contactor, 2 traction controller contactors and a hydraulic contactor all located in this compartment area too. weve managed to resolve most issues but the last one fault were stuck with is on the left motor controller which is flashing 1,3. we know its field open fault and the symptoms are that the contactor drops out when we press the accelerator pedal. weve fitted a new drive motor as it was kaput and also new controller. any info wold be a great help. thanks.
  • Posted 28 Mar 2015 04:07
  • By feebs
First thing you need to establish is which brand of Bendi you have, either a Translift or Landoll built truck. Based on your location, I will assume it is a Translift. Is your truck a rear drive or front drive?
As has already been stated, more information on your truck is needed to get you the correct information.
  • Posted 27 Mar 2015 00:01
  • By ChrisK
  • joined 28 Feb'14 - 142 messages
  • Kansas, United States
serial number might be helpful
also what series is this unit?
they changed the control system on these trucks between the series III and series IV, they are 2 totally different worlds apart
  • Posted 26 Mar 2015 21:36
you would need to include a serial number to be able to get ANY help, AND your local Bendi dealer is the only correct place to acquire manuals.
  • Posted 26 Mar 2015 11:19
May 14, 2026 - Blair Athol, South Australia, Australia
